jsayko1@gmail.com
Im in west FL where we successfully rely on 200 kHz traditional sonar for bottom recognition when bottom fishing in under 300'. Occasionally go the the keys for misc bottom fishing and trolling. Have not yet tried deep dropping or electric reels..
My local buddy is redoing new electronics on a sport fisher, definitely installing Furuno, w DFF3D, radar, sat compass, multiple TZT3s, trying to narrow down how many simultaneous sonar frequencies to run, while avoiding interference. Here are some options:
Choice 1 - 3 frequencies) Give up 50/200 traditional sonar and use a high / low chirp transducer for bottom fishing, while using the DFF3d also as a wider, flatter, less detailed solution for trolling. (This probably means giving up the ability to identify "swiss cheese" bottom) This means installing DFF3d (165 kHz) and a 1000 watt high / low chirp transducer on the TZT3s (question: does the high chirp interfere w the DFF3d?)
Choice 2 - 5 frequencies) Install 50/200 1000 watt traditional sonar w a 1971f running separately from the TZT3 system. Also install DFF3d w a 1000 watt high wide / low chirp transducer on the TZT3s (question: what frequencies AND/OR frequency ranges (if any exist) can i select on the HW / L chirp transducer that will not interfere w the 50, 165, and 200 that are also broadcasting simultaneously?)
Choice 3 - 4 frequencies and likely an option only if choice 2 won't work) Install a medium chirp 1000 watt transducer w a 1971f running separately from the TZT3 system. Also install DFF3d w a 1000 watt 50/200 traditional transducer on the TZT3s.
Choice 4 - 4 frequencies and likely an option only if choice 2 won't work) Install 50/200 1000 watt traditional sonar w a 1971f running separately from the TZT3 system. Also install DFF3D w a medium range chirp 1000 watt transducer on the TZT3s.
Any help with the questions / choices above would be appreciated.. Or any other suggested choices I am missing. Choice 2 seems to be especially advantageous, if it is even possible...
Thanks, Jamie
Thanks, Jamie
