I am upgrading a mast mounted Furuno analog radar with the DRS2DNXT. I am concerned the new antenna cable will not fit into the mast's cable conduit. I understand the Radar dome can be wired using a RJ45 ethernet connection and separate power wires. Does it matter which of the wiring configurations for RJ45 is used, T568A or T568B?
I recognize the concern for water tight connections.
The TZ3 plotter brochure identifies that an iPad or a MFD can be used as a mirror display. What is the best option to mirror the Plotter radar display from a nav station install to the cockpit. iOS app? HDMI cable? something else? I have a remote encoder that will be installed in the cockpit. I need a screen to view the displayed data.
I have a Vesper XB-8000 AIS transponder. There is a wifi gateway and a nema 2000 connection. What is best practice to connect the AIS to the TZ3 plotter to get the AIS data interfaced with the Radar display function?
