Last season I purcahsed a FCV-585 and did not upgrade teh existing transducer
When initially installed the temp display worked fine
After 10 hours of use the temp dispaly went to 99.9 and stayed there
The existing transducer is FRN-ST-02MSB 144333
With the boat out of the water I just purchased a new FRN-ST-02MSB transducer assuming that the temp sensor is bad
I see that Furuno specs reference Triducer 525ST-MSD Code No.: 000-015-263
I note that in a previous post the Product ID is now 525STID - MSD
Looking at the photos of this transducer I note that the body is not the same 2" diameter as the old FRN-ST-02MSB
I want to simplify the installation - will the 525STID fit in the existing 2" hull hole? Is there a collar the fill the difference?
