Tom Stewart
Vessel: Tiara 3500 Express
Current Electronics: Garmin 7212, 5802 and B60 Airmar Transducer (no chirp) with 2 3/8 hole. 20 degree tilt at current mounting location.
New pkg includes:
TZ Touch XL 13 x 1
455 kHz side scan x 1
DRS4D-NXT 24" x 1
Questions please:
Tom
New pkg includes:
TZ Touch XL 13 x 1
DRS4D-NXT 24" x 1
Questions please:
- I need to purchase a new down shooting chirp transducer. Usually, I fish in 300' of water or less on the Gulf Coast of Texas...Ocassionally a deeper run, but not that often. I am thinking I should get a LHW transducer. Can you please recommend a tranducer? I am getting mixed/incomplete responses.
- I do want to continue to use my Raymarine ST7002 auto pilot which is n 0183. What cable do I need to make this work?
- Do I need a Maretron n 2000 starter kit?
- Since the XL will handle two transducers and the radar does connect directly to the XL, do I need a n 2000 kit for anything else?
- The TZ Touch XL has a gps antenna built in......I do have a spare GP 330B from my other boat. Should I mount this GP 330B to this new setup? Any advantages to adding the GP 300B? If I do need or should add the GP 330B, what cable do you suggest.....Connect directly to the TZ Touch XL or to a n 2000 network?
- I have a ruggedized tablet to use on the boat that has wifi and bluetooth. I assume I can cast from the TZ Touch XL to this tablet. Lets say that I put move the chartplotter to the tablet; will I be able to control the sonar from the table or is it just a display? Second question regarding this casting...Say that I am napping on an overnight trip and I want to cast the radar to the tablet and carry to this tablet to bed with me.....if I have peremiter alarms set, will it use the speaker on the tablet as an alarm or only alarm signal to the helm XL unit?
- Do I need any kind of fairing block for the side scan....my plan is to mount it right on the keel just forward of the prop shafts.
Tom
