Hi
I have recently bought a Boston Whaler 305 Conquest, which was repowered in 2021 with 2 x Mercury Verado V8 outboards.
I have an issue where the Navpilot 711 is not moving the outboards at all, and is showing an error "Rudder Drive Error".
The NavPilot 711 is connected into the hydraulic power steering lines from the helm via a Danfoss Solenoid (ie it doesn't use a reversing pump).
The Navpilot does have a Rudder Reference Unit installed as well, attached to a bar which links the 2 outboards together, and this is reading correctly when I manually turn the steering wheel.
After having an electronics tech out, the Navpilot is working in full, and sending current to the solenoid. The previous owner of the boat states that he has never used autopilot, so wasn't any help with solving the issue.
After doing some of my own research (and my very limited knowledge), and having the solenoid replaced, it may be that I actually need a pump rather than a solenoid as there isn't enough pressure in the lines to turn the 2 outboards?
Although it's not an issue with the 711 itself, wondering if anyone may be of help.
