TailWhip4Guy
I am considering installing a NavPilot 511 with the PG500 Heading Sensor. Two questions:
1) Can I connect the older NP511 and PG500 to a newer model TZT3 MFD?
1a) If possible do I do it through NMEA2000 or NMEA183 or through a different connection?
2) With the NavPilot300 and the PG700 it appears a Rudder Feedback sensor (FAP-6112) is NOT required. Is a Rudder Sensor required for the older Navpilot 511 and PG500 or can I run the AP with just the PG500?
Thank you.
Thank you.
