I used to be happy with the performance of my Navpilot 500 autopilot in my 100 ton trawler. I recently had to change my heading sensor (I now use this: https://www.svb24.com/en/digital-yacht-compass-sensor-hsc100.html). It transmits the heading to the Navpilot with 10hz and the technical installation is good.
On flat waters everything works well but with just a little bit of sea, the heading fluctuates a lot and jumps constantly 5-15 degrees back and forth as the vessel pitches and rolls. This causes the autopilot to fight the rudder to try to keep a steady direction against the constantly fluctuating heading data it receives. No amount of fiddling with the autopilot settings, especially the "weather" and "rudder gain" settings but also changing between the auto/self-learning and manual modes, sufficiently dampens the autopilot's furious rudder adjustments.
I'd actually be happy just using COG as the heading, which the Navpilot defaults to if I disconnect the heading sensor. However, until the ship has moved enough to actually generate a COG, without a heading sensor connected the Navpilot unit will issue a constant and incredibly annoying audible alarm for the missing heading data. This causes port manouvers to involve swearing and constant disabling of the alarm, which the Navpilot of course reacts to by restarting the alarm every 30 seconds or so.
Have I missed an important setting or other configuration parameter of the heading sensor setup or the autopilot itself? Any tips or advice? This can't be the first time a Navpilot installation has had to deal with "nervous" heading data.
