I have a Navpilot 300, an SCX20, and a TZT3 chart plotter. In looking through the settings, it shows 12 mph for the cruising speed of the boat. The boat is a 41 foot trawler that cruises at 7 to 8 mph with a top speed of 14 mph. Should the cruising speed in the settings be set closer to 7 to 8 mph?
When navigating a route, the trawler tends to weave off of the line in one direction and then correct past the route line in the other direction. It is like it is hunting for the correct heading. This happens every time, whether heading into current, running with current, and in different wind conditions. I would like the trawler to run more tightly to the navigation line. What do I need to do to achieve that. Rudder indicator is tight and aligned correctly, the AP computer is about 20 feet forward of the rudder, ram, and pump. The self learning setting is on.
