NavNet VX" 1834C Navionics
The Navnet vx2 system was available in 2 versions. One worked with C-Map and the other with Navionics. The charts are not interchangeable.
Our testing of Navionics+ maps are that they don't work properly for the Vx2. Anyone still running Vx2 or NN1 machines would have to convert to C-map if they wish to purchase new compatible charting.
Vx2 should use the MAX maps in SD card format. You do not want charts larger than say the East coast and Bahamas. If it includes the entire USA it is too big.
Dear Johnny
Thanks for your replay.
Well the only map that I found is C-MAP Max-N+ W or MAX-N. I have the Navnet VX2 RDP-149. I dont find NT+ for my region.
Do you think that it will work?
That seems to be a "wide" card and as Johnny said it might be too large. You should look for the area split into 2 regions.
Unfortunately none of us at Furuno USA are familiar with the Med so you might want to speak with a local Furuno agent. You might also want to check the C-Map website.
You should contact your local Furuno Distributor. They are more familiar with that area. I suspect the chart you want is EM-M017.43 - MEDITERRANEAN AND BLACK SEA. You should verify with your distributor or directly with C-Map at 1-800-424-2627
