Good afternoon.
I have a Navnet RDP 139 setup which I am trying to obtain some parts for and am hoping some kind folks could help me with the setup please?
OK, I have a RDP 139 - but require UK CMAP for it to use between UK and Jersey.
I have a PG500 and link lead which is fine.
The plotter does not pick up any location so I am guessing as an older system it will require a standalone GPS device - though i'm not sure which will work with this system?
ETR 6/10N network sounder hub - but no transducer to connect - would be nice to have a through hull sounder to link into this.?
Finally I also have a netgear EN106 TP switch (hub) so im guessing like the newer TZ series that this would work as the backbone to connect the devices.
I am currently checking an old radar unit to link into the system although i think most of the older ones will work with this system.
Most important bit for now is to get the plotter up and running.
Any help would be much appreciated!
THANKS in advance.
THANKS in advance.
