Navnet 2 update for the earlier models?
I have the earlier model sn 4345-4878 where do I find the latest update? also where does it interface with my PG1000 heading sensor? the boat builder installed it with only two cables leaving the center port open. can I pick up that signal from data port 2 along with sending it to my icom 400BB and to the yahama smart gage?
That serial number unit was sold in 2007 and was programmed to support C-map mapping. You would download the CCFL update and the update instructions from our web site under the SOFTWARE tab of the product. Here is a direct link to the product for your convenience.
http://furunousa.com/Products/ProductDe ... t+Plotters
You should use the heading port of the unit (Data port 3) to connect your PG1000 compass heading data.
I wasn't sure exactly what the last question was; but if you are asking if you can connect more than one NMEA 0183 listener, to a single output, the answer depends exactly on what is being connected. VHF radios pull a lot of current so you can only have two items connected.
