i got a navnet 1 and a 6k radar. when i rig the radar i turn it on it goes to stand by when i press transmit it shuts down . do u need a different power supply cord ? does radar need to be grounded to batt.
the 6kw radar can be powered from the NN1 display. you should not need an additional power supply unit. It does not sound like grounding is the issue, but rather low voltage or even a short w/in the signal cable (cable between the display & the antenna).
