NavNet 1 RPD139
I just picked up this unit that was in working order when it was pulled from another boat. Problem is corrosion got to the power cable socket and the ground pin broke off on the unit and the black wire split in half on the cable side of the plug. Is it possible to get the part numbers for the male and female side of the power plug for this unit? I am also having a hard time locating a manual online for this unit, is there one still available?
For the RDP139, you will find the manuals posted under the product part number (based on the radar connected or lack there of). Since the manuals are the same for the series, you can use the manuals from any NavNet series one, product pages. Here is a product model you can use.
http://www.furunousa.com/Products/Produ ... t+Plotters
Click on the tab that says "Manuals and Documents".
The part number for the three pin power chassis jack for this unit is 000-138-932.
A new power cable (that has the connector melted on for water protection) is 000-154-025.
These items can be ordered with any authorized Furuno dealer. Here is a direct link to our dealer locator if you need to find one.
http://www.furunousa.com/Support/DealerLocator.aspx
