Hi trapper, I would work in the following order of priority:
(1) Distance from magnetic disturbances, specially those that may change like wires carrying high currents that switch on and off as they cannot be covered by compensation.
(2) Distance from bigger magnetic iron, like engine blocks.
(3) Distance from center of motion because of acceleration forces.
Good sensors, and the PG 700 is one, are quite good in smoothing out the acceleration forces (swinging of gimballed flux gate coils) while still rapidly and correctly updating heading with the help of a gyroscope. So the problem of being off the center line or above the center of motion isn't very big.
Problems caused by proximity of iron or wires with stronger currents are most imminent when very close to the sensor and their effect diminishes with the share of distance.
Use a hand-bearing compass and moved it around the area where you plan to mount the PG 700 and if it stays steady you should be ok with respect to (2).
In any case, you should try to align it parallel to the midships line so that you do not have to apply to much of a heading offset after installation. A bulkhead often helps as a reference.
As you don't have a steel boat, you shouldn't have too much of a problem.
