G
genxxxx
I have a question....How many transducers can be installed on an NavNet TZtouch2...Could these three Airmar transducers connect to the TZ or via a Furuno Hub of some kind like the BBDS1 or DFF...The transducers are B175L - B175 - B175 HW...these three transducers cover combined 40 to 250 kHz...The hull being 19 degrees there is no flat surface to mount a larger PM111LHW type transducer...I want the three transducers thru hull flush mounted at the appropriate adjusted angle....Can you please advise if this type of installation is possible.
