FRU-MJ10CCB12-300 is listed as an adapter cable to connect a LH chirp transducer like a 265LH variant to an FCV 800. Does this effectively split the L/H frequencies so that the 10 pin ends essentially each see single frequency chirp transducers? For example, could you connect a B265LH transducer to this cable and then connect one of the 10 pin ends to the FCV 800 XDR2 port to have the high frequency on that unit and the other 10 pin end to another single frequency chirp transducer 10 pin port like on a GP1971F to have the low chirp displayed there?
