Hi
I have an MFD12, DFF1, 525TID-TMD, BBWGPS already hooked up on my boat and working great. I just received a DRS4D, HUB 101 and a PG500R which I hope to install this weekend however I have a few question I hoped you would help me with to be sure I get it right the first time. I currently have the BBWGPS connected to the Data 1 port on the MFD12 and the DFF1 to the Ethernet port of the MFD12. For this new install I understand I can leave the BBWGPS connected to DATA 1 but disconnect the DFF1 Ethernet RJ45 so as to connect the HUB 101 Ethernet RJ45 plug.
1) The Hub 101 is now connected to the Ethernet port of the MFD12 but which port from the HUB 101 or does it matter?
2) Does the HUB 101 power cable go direct to a live 12-24 volt fuse/breaker and stay with power or does it need a physical switch in the cable to turn it on/off?
3) The DFF1 Ethernet RJ45 now plugs into HUB 101 but at which port of the HUB 101 or does it matter?
4) Does the DRS4D power cable plug into the MFD12 DRS port next to the DATA 1 port and the DRS4D Ethernet cable RJ45 to HUB101, again which port of the HUB 101 or does it matter?
5) With just a single MFD12 on the boat do I leave all the internal DIP switches off on the HUB 101?
6) The PG500R connection to the MFD12 is baffling me! As practically as I can discern it indisputably connects to the 18 pin DATA 2 port of the MFD12 utilizing the 18 pin connection cable that came with the MFD12 mated to one or both of the cables supplied with the PG500R. How this is accomplished is bewildering to me! Using the supplied manuals and the internet I have deduced that there are two MFD12 ports (Data2 & Data3) that can be accessed from the 18 pin cable using different wires. I think to use the left PG500R port and mate the PG500R 7 pin connection cable to the 18 pin MFD12 cable at Data2 thus – PG500R 7 pin cable white wire to the brown wire of the MFD12 cable. PG500R blue wire to MFD12 brown/white wire. PG500R yellow wire to MFD12 red wire. PG500R green wire to MFD12 red/white wire. PG500R fused red wire to 12 volt + and PG500R fused black wire to 12 volt – . Or do I have to use the 6 pin cable from the middle PG500R port either by itself or with the 7pin cable OR WHAT?
7) When installing these systems do you prefer Aleve, Tylenol or just plain aspirin?
Look forward to you reply
Best regards- Tarpontony
