:angry :angry :angry
Just recently had an install done on my boat by an authorized Furuno dealer. It was a mix of new and pre-owned Furuno parts/equipment. The install consisted of:
MFD12
RD-30
FCV585
DRS6a
B-164
Everything is working except for the DRS6a. It cannot be found by the MFD12. According to the dealer that did the install, here's what they tried:
1. Tested cable from other furuno dealer with cable testers – tested OK (prior to cutting and supposedly after cutting)
2. Tested cable from other furuno dealer on drs6a – radar not found on MFD12 (after cutting)
3. Tested brand new DRS cable on drs6a – radar not found on MFD12
4. Tested cable from other furuno dealer on brand new DRS4D – radar found on MFD12
5. Tested brand new cable on brand new DRS4D – radar found on MFD12
At this point they proceeded to tell me that the transmit unit was bad so we pulled the board and sent it back to the authorized Furuno dealer I bought it from. They bench tested it and found it be 100% operational. Threw it in a gear box and it works perfect directly connected to an MFD12 and through a hub101.
So as of right now I'm at a loss. I'm an IT guy by trade and I'm leaning towards a LAN cable failure. The dealer doing the install DID cut the cable to shorten it between the MFD12 and DRS6a, but it still tests OK. That being said I've seen cables test OK in my own practice but are still junk because of bad crimps, etc. My question is though, looking at steps 1-5 above,
Given the fact that the cable I gave the dealer was run through my t-top and just long enough to fit into my gearbox, I'm wondering if steps 3 and 4 really did occur above?
What do you guys think it could be at this point? I'm not even sure where to begin troubleshooting this but I'm getting slightly irritated. Should I run just a regular LAN cable from the board to my MFD12 and just test it that way? Maybe they crimp bad/weak connectors on the end that test OK but still are no good. Is this possible? The ends only have 2 pairs of wires in them, are all 4 pairs needed to power the DRS6a with the MFD12?
Thanks in advance.
MFD12
RD-30
FCV585
DRS6a
B-164
Thanks in advance.
