I am about to purchase a M260 to be used with an FCV 587. My current transducer is a P66. Since the M260 won't give a temperature reading, how can I connect the P66 to the 587 for use a a temp sensor? I've been thinking of a 6 pin pig tail for the P66, then connect the m260 and the P66 together via a Y Cable connector (AIR-033-270) then finally to the 587. Is this correct?What color wires should be connected at the Pig Tail/P66 junction?
