I'm playing around with some generic IP cameras so see if I can get a low cost option to work. The setup seems pretty common across brands and I'm following the directions for the Axis IP cams.
I'd just like to confirm that the Video server referenced in this manual is optional and only required if there are analog cameras in the setup?
Also, I currently have a Netgear unmanaged switch for my network and need to add a POE unmanaged switch for the CAMs. I assume just connecting the two switches via open (non POE) ports will work fine?
