I recently installed a full system to include the TZT2 12" display. Everything appears to be up and running and the TZT2 is recognizing all the separate components via the network and NEMA hub. The unit came with Version 2 software so I performed the upgrade as per Furuno instruction to Version 4.01. The upgrade seemed to work since I can go into the system self check and it displays Version 4.01. Funny though that when I connect to a network to check for upgrades it says I'm up to date with Version 2.0.
The other issue I'm having is just trying to set the correct date and time. I set the UTC time but the date keeps coming up to Jun 1, 2016 and the time is off too. I can't find a place to set the date.
Also, why are the browser selections grayed out?
Thanks.
Thanks.
