Imported routes not saved
You might factory reset the TZT2 and then import the routes/points. If it continues happening then it is possible there a formatting problem with how the routes were created or converted. You could always open a case with tech support and send them your file.
Sent email to Furuno support, no response yet.
Called Tech Support in MD., they suspect recent software update to Nobeltec Time Zero, V3.3.0.38, which re-enabled Active Captain "may" be the problem. They are waiting on TZ2 software update from Japan.
In the meantime I will try factory reset today.
