icom nema 0183 to tzt2
CAPTDEVONC
Wiring the icom to tzt2 green and yellow i believe at the icom side ,i need the tz side and if anything has to be switched in the unit ?
thanks
It's going to be white(+) and blue(-) from the TZT2 to send data out via NMEA0183.
That is going to depend on what kind of data you are trying to receive on the radio. In the "Initial Setup" menu, you will see where it says "NMEA0183 output" on the list and you can see what NMEA0183 sentences the TZT2 can transmit or you can also find the information in the back of your installation manual.
