PugSndBoater
Forking this thread from the previous thread about user-objects not syncing across displays, since that more basic (and disruptive!) issue has been resolved.
How are the TzTouchXL MFDs and the Navpilot 711C aware of each other's state and how do they control each other? I don't mean the navigation data part. I know the navigation data flows from the XLs to the NAvpilot using NMEA2K PGNs (129283, 129284, and 129285), which seems to happen correctly, and our vessel can navigate a route on the autopilot. I mean more directly how do MFDs put the Navpilot into "A" or "N" mode, how are the MFDs aware of and control the state of the 711C autopilot (e.g. adjust the chosen heading with on-MFD buttons), and how do the MFDs stop the Navpilot (put it back into Standby "S" mode) from the XL display? That state-control and awareness of the Navpilot by the XLs seems to not work with our MFDs. It worked on our old four TzTouch2 installation, so I'm trying to sort out what's different or missing with the new four XLs.
- Everything is connected to the NMEA2K canbus.
- TzTouchXls are outputting PGN 129283, 129284, and 129285.
- TzTouchXLs have the same NMEA2K device instance (0), per configuration guidance form FishTech, and the same system instance as everything "0"
- Navpilot is set to output PGN 127237 (heading/track control) and 127245 (rudder). Rudder angle shows correctly on the MFD (e.g. in an Instruments page).
- Settings -> Routes -> Route Settings -> Navigate with NAVPilot is enabled on all four XLs
- On the 711, Nav Option -> Nav Data Source is set at Source2 for the TZT16X. Source 1 is blank (---------).
- Navpilot-700 is visible on the XL displays (it appears in the list at Initial Setup -> Sensor List -> Can Bus Sensor)
- PGN sentences 129283, 129284, and 129285 light up (turn black indicating receipt) in the Navpilot's diagnostic screen.
- If I start navigation from the one XL that I selected as the Nav Data Source 2 (select route, start navigation, tap "Yes" to "Do you want to navigation with the Navpilot?" dialog), the Navpilot starts in "N" mode and I get a "NavPilot activated" yellow banner, but then I immediately get a "NavPilot deactivated" yellow banner on the XLs. The actual Navpilot remains activated in "N" mode but the TzTouchXL seems unaware of the NavPilot's state and is unable to control the NavPilot hardware. Waypoints will continue to update correctly and the route can be navigated successfully on autopilot, though. If I stop navigation on the XLs (Stop icon in the header bar) it doesn't put the NAvpilot back into standby mode like it used to on the TzTouch2s.
- If I start navigation from one of the other three XLs, it doesn't activate the Navpilot hardware at all (remains in "S" standby mode), but I can start navigating manually from the 711C screen (NAV button -> push control knob) and navigation will activate, waypoints will continue to update correctly, and the route can be navigated successfully on autopilot. Just like above, if I stop navigation on the XLs (Stop icon in the header bar) it doesn't put the Navpilot back into standby mode.
- If I start navigation using the controls of the XL (e.g. Navpilot item added to the XL's Data or Route left-swipe-in side menu) the Navpilot activates in "A" mode (showing "Navpilot activated" yellow banner), but then I immediately get a "NavPilot deactivated" yellow banner on the TzTouchXL. The actual Navpilot itself remains activated in "A" mode but the TzTouchXL seems unaware of the NavPilot's state and is unable to control the NavPilot hardware further, e.g. to use the MFD arrow keys in the Navpilot item to change the desired course. Like above, this also only works to active into "A" mode on the one MFD configured as a source in the Navpilot, which didn't used to be the case on our TzTouch2 installation.
- When underway in "A" mode on the Navpilot, if I turn the knob to adjust the chosen heading, on the old TzTouch2s I used to see the heading line drawn forward from the My Ship icon on the MFD to indicate the new desired course, but I no longer see that on the TzTouchXL (I just see the normal vessel heading line from the sat compass, same as when the autpilot is not running). Maybe that's a clue to something amiss?
