High, Medium, and Low frequency
Is there any way you could have an R599LM as well as an R111LH mounted in a boat and be able to have both of them hooked up to use the Low and Medium off the R599LM and then the High off the R111LH without having to disconnect transducers from the DFF3 or would you be able to get a FCV-1900 to run all three frequencies interchangeably? I'm really wanting the full spectrum of frequencies on my next boat but I just dont know if its possible.
thanks
Talin Strange,
We have done this on a couple of vessels using CM599LH and LM transducers with a FCV-1900B. We run the HF channel through a switch to change from HF and MF. However you still need to reprogram the sounder for the frequency you want to use.
Interesting so it can be done. I'm definitely wanting the full frequency spectrum if its possible and it looks like it is. Another question, is the sounder processor unit for the FCV 1900B chirp or 1900 non chirp more powerful or does it carry any more advantages over a DFF3 sounder module? And would you be able to do the same full spectrum of frequencies with the DFF3 as well?
Tailin Strange,
The 1900 is like the DFF3 (CW). T
The 1900B channels can toggle between Chirp or CW transmissions.
So is it possible to do this switch on a DFF3 and R111LH and R599LM with a TZT2 or TZT2 BB then? Which is more what I'm after since it can be networked with another TZT2 and TZ pro ver 4. I'd like some more info on this. I'm having a boat built shortly with a rather extensive electronics package. Is there anyway you can email me or private message me so we can talk more about this subject.
Mickey
