Hey Guys…Currently have transom mount transducers namely ss904, tm54 dff3d and 175 chirp.
Currently have all three mounted in the center between my twin engines. I start to lose bottom around 20 mph and my auto range jumps all over the place because of the loss of bottom. I have a feeling this is happening because my motors are counter rotating and putting the wake so to speak between the motors. I am considering moving a couple of the transducers to the opposite side of each motor to reduce water turbulence and the rotation of the props. Do you think there’s a minimum distance radially that they away from engine? Or give me any ideas to improve at speed as they are all mounted 1/8” below hull
My boat is a 27 ft aluminum hull. Photo for reference
