northcaptain
Hello all,
I have noticed that several of my Furuno's equipment have a small screw with a Earth sign on it, presumably for bonding to the mass in a plastic boat; but i am wondering if i should tie all equipment having this characteristic to the metallic hull of my boat ? Right now the only equipment which is electrically connected to the metallic hull is the isolation transformer (AC) and the inverter.
Does the bonding of equipment to a common mass is for balancing the electrical potential or is it to be able to better survive a lightning bolt if it ever occurs ? If the later, then not sure the bonding would help because the boat is metallic, if hit by ligthning the current will flow outside of the hull (faraday cage principle).
Any information regarding good practices for installation on Furuno's equipment on a metal boat are welcomed,
regards
regards
