S seanthings New member May 10, 2021 #1 can not find structure using others numbers Can always find if I make them
M Marlin My Darlin Member May 11, 2021 #2 Can you give an example of the format you're using when you enter the GPS numbers vs when you are using other numbers?
S seanthings New member May 12, 2021 #3 So my current position format DDD MM.mm` Waypoint # N 28 18.870` Looked at three different maps and got three different numbers for same waypoint/waypoint/reef It`s my understanding that most all maps use this format after 1985
