Hi,
I've just upgraded the plotter to a 1971f and have finally bridged two NMEA networks on the boat so that I now have instrument data displaying on the plotter. When I select sonar, it displays depth and readings from the transducer however when I select instruments, the depth is '--'. I can't see where to change the source of this because if I can have a screen which has the Map, engine data such as coolant & rpm and also depth, I'd be ecstatic!!
Thanks in advance for any assistance!
Kind Regards,
David.
Kind Regards,
David.
