GP 1971 update
Don S
HI guys, i am looking for the GP 1971 software update, can anyone direct me? its seems very cryptic to locate this.
thanks a lot
The software was pulled due to a software bug. A new version should appear under the product page of the unit sometime today. We just received a corrected version.
Ive just done an instllation of a GP 1971 with a TM185m. The unit picks it up as a TM150m. (300w). Would you expect an issue?
That isn't right. You are 100% sure that the transducer is a TM185M? The Airmar TID chip is what identifies itself to the sounder. The TM150M is a 300w transducer and the TM185M is a 1KW. I would not expect the unit to give very good deep water performance. Do you see the TM185M in the setup for doing a manual selection? If it is a TM185M then i recommend you see if you can swap to manual selection and pick the correct model.
Hi Johnny can I please get the v 3 software to help out a mate. They don't have the wireless radar installed.
Many thanks!
Many thanks!
:furuno
Is was a minor revision change. Was version 3.00.01 and now something like 3.00.04 but yes the posted version is the corrected software. The problem software was removed few a few weeks. It is now replaced with this current version. Several customers have used it already without any problems so I know the download is good.
Hi Johnny Sorry for the late reply. Yes that is 100% correct a TM185M. Ive just installed a GP1971 with a P66 and it indicates it again as a TM150M.
No there is no TM185 options available t select. I see the latest update is up again i will follow up on that and see if it changes. thanks
