GP-1971-F & TM185 transducer
SodaKodiak
Recently purchased a TM185M transducer to support my GP 1971F, (I also use a GP1871 as my back-up).
The menu options do not allow for the TM185M. When I select the 1kw transducer option the depth reads 10 times or more actual depth. Also no temp sensor info. Using my 1871 with airmar 66 525ST PWC.
Somewhere on this forum, I saw suggestion to select B175. This was a post in 2019 from Johnny Electron.
Are there any updates since then?
Also having trouble getting ACCU FISH to work.
SodaKodiak
Greetings,
FishTech is 100% correct, as of latest software it lists the TM185M now (see attached).
Hope this helps, :sail
- Maggy
Thank you. Always a good idea to update. How often should I expect to update software?
Is there a way to be notified?
SodaKodiak
SodaKodiak
Furuno isn't really known for frequent updates, so if an update is about to be released we generally post something in our News room and notify dealers. Our suggestion would be to just monitor the News room periodically or check in with your Local Authorized Furuno dealer.
Hope this clarifies, :sail
- Maggy
