I have a MFD12 and two heading sensors: a recently-acquired SC-30 and a PG500, which was my original Hdg source. Aside from the MFD12, various Repeat instruments (RD33, etc) and a laptop running MaxSea Navigator also use Hdg….but most importantly, the (0183) autopilot needs a good Hdg feed.
Currently, the PG500 is connected directly to the autopilot AND via its 2nd 0183 output, to an MFD input port. (The SC-30 will be connected via a DRS’s CanBus port). I’d like to set things up so that Hdg from both is available on the network, with priority being given to the SC-30.
I was planning to do this by removing the direct connection between the PG500 and the autopilot and instead, feeding the pilot HDG from a MFD output port. I would then set the SC30 as the priority sensor in the Global settings.
However, having read a post by Johnny Electron back on Jan 30 (Heading-PG500 vs PG700 ), I learnt that sending Hdg from the PG500 via the MFD slows the signal down too much for use by a pilot; he recommended putting the PG500’s output onto the N2K network via a converter instead.
I have a converter and could do this. Have I understood Johnny correctly? Is this the way to go?
