furuno
hello.in furuno 1670 the cause for more reason while working and showing the degree, after some time you miss the measurement of degrees of measurement.??thanks.
Once again sir it is not quite clear what you are asking. However, if you are asking if temperature probes in transducers can go bad, then the answer is yes they can.
Either a bad transducer, bad unit, or someone made a setting change. I suggest you take it to a local Furuno dealer to check out.
