Furuno FCV 295
Jsaronitman
FCV 295 I have a Airmar R109LM hooked up it, is it possible to hook up a second ducer to the unit, if so new Transducer will be a Furuno B275LMW
No. There is only 1 connection for low freq and one for high frequency. Depending on the transducer, the low or high frequency connection may be connected to a medium frequency.
Thank you.. now if I wanted to just hook up the B275LMW to my fcv295 what would be the wiring diagram for that ducer to machine, and correct settings to select transducer
Mahalo
I looked on Airmar's webpage and don't find a B275LMW...I find a B275LHW. Is that what you mean?
Jsaronitman,
I've found that when testing the B275LHW that is really performs well with the FCV295 when you select the following frequencies: 42kHz for the Low Frequency, and 155kHz for the High Frequency.
Keep in mind that these following frequencies have been "locked-out" on the FCV295 due to combating any potential inverter noise:
53-65kHz, 111-139kHz, and 171-183kHz.
- Deep Blue 🦑
Jsaronitman,
Yes the R109 series transducers all use the same housing and have the same bolt patterns. The only difference between these transducers are the transducer's elements.
-Deep Blue 🐙
