Furuno FCV 295
No. There is only 1 connection for low freq and one for high frequency. Depending on the transducer, the low or high frequency connection may be connected to a medium frequency.
Thank you.. now if I wanted to just hook up the B275LMW to my fcv295 what would be the wiring diagram for that ducer to machine, and correct settings to select transducer
Mahalo
Jsaronitman,
I've found that when testing the B275LHW that is really performs well with the FCV295 when you select the following frequencies: 42kHz for the Low Frequency, and 155kHz for the High Frequency.
Keep in mind that these following frequencies have been "locked-out" on the FCV295 due to combating any potential inverter noise:
53-65kHz, 111-139kHz, and 171-183kHz.
- Deep Blue 🦑
Jsaronitman,
Yes the R109 series transducers all use the same housing and have the same bolt patterns. The only difference between these transducers are the transducer's elements.
-Deep Blue 🐙
