Little background information:
I have never installed one of these before, so I'm asking for guidance.
I just installed a Furuno 1815 with PG 700, AIS FA-50, NMEA 0183 converter (IF-NMEA2K2) to CAN or NMEA 2000, I can see my other 2K devices on my backup GPS that is NMEA 2K ready, it also has a device list, with all 2K devices shown, so I know I have communication termination set correctly. I've also connected the terminal board to the corresponding NMEA connections outlined in the pictorial diagrams and schematics on the back page of the Furuno 1815 manual. Reference Drawing number C3666-C01-H "Marine Radar Interconnection Diagram"
I did build a secondary network, RJ-45 interconnect for AIS support, as well as bluetooth support on Victron lithium power battery management system for Shipboard Electronics, including building an electronic drain with capacitor isolation so I have no current feedback or noise on my boat ground. All ancillary systems are completely isolated from lead acid boat battery engine systems.
Again: the back page of the Furuno 1815 manual
First question does this sound correct? I have the NMEA2K2 is connected to terminals 3,4,5,6, coming from the radar WHT, BLU, YEL, GREEN, From the IF-NMEA2K2, PINK, to 3 terminal WHT, PINK WITH BLACK STRIPE to Terminal 4 BLU, LIGHT BLUE YELLOW STRIPE to Terminal 5 YEL, GREEN STRIPE to Terminal 6 GREEN. If not please advise?
Second question is the Furuno model 1815 capable of bi-directional communication? The (IF-NMEA2K2) is blinking power is on, still no communication to display unit on the Furuno 1815, in test mode I see NO NMEA inputs at all, my PG-700 seems to be calibrated and is on the device list on my backup GPS that is a Garmin and NMEA 2000 network. The (IF-NMEA2K2) is also on the device list on the Garmin. It appears all NMEA 2000 devices are seen on the GPS, but no communication to the Radar display, Radar rotates sweeps and shows radiation pattern and contacts, but no heading information, Longitude or Latitude information, my PG-700 should be feeding compass or heading info via the NMEA 2K network to 1815 display, right? If not what do I need to have this information displayed on the 1815/RDP-157?
My other problem is I bought a used AIS FA-50 what is the service name and password, will this allow me to reset the unit so I can load my boats MMSI and name for the transponder? I can access the unit via the web browser with default IP address, but I can't make any changes to the FA-50. Please help.
Also, I have the AIS FA-50 feed through the junction box to the terminal board for the 1815 display unit RDP-157, what is the interconnect to the display, colors codes from the AIS to 1815 display or RDP-157. Would this be NMEA 0183, correct? Coming from the AIS, I don't see NMEA 2000 or CAN network interconnect on the FA-50, right? Do you need the color of the wires out of the FA-50? or can you look them up? Would it help if I send photos? Please help.
Can the Furuno 1815 display/RDP-157 support both protocols NMEA 0183 and NMEA 2000 on NMEA1 input and NMEA2 inputs respectively? According to the schematic I referenced earlier there is a 3rd NMEA port address, simply named NMEA3.
Finally, I also want to integrate my VHF radio into the NMEA 2000 it is NMEA 2000 ready, and has internal GPS, AIS capability, DSC calling etc... should this also read through to the Furuno 1815 via NMEA 2000 network? I thought the (IF-NMEA2K2) allowed for integration from NMEA 0183 to a CAN network.
Please advise, I'm starting to regret my purchase of this Radar unit, I should have purchased a NMEA 2000 ready system, it might have been a better fit for my shipboard application.
