808double.e
I have an FCV 1150 paired with a CM599LH CHIRP transducer. Is there a single frequency, on the high and low side that the transducer and/or the 1150 operates best at? For example, 42 Khz on the low side, and 195 KHz on the high side.
Also, can the 1150 be set at 42 Khz as my fundamental frequency, with a bandwidth of 20 KHz on the low side, and 155 KHz fundamental, with a 30 KHz bandwidth on the high side?
Thank you very much
Thank you very much
