FR-7062 with RSB-007 scanner - brg pluse error
cptkatz
Hi:
Have a FR-7062 with RSB-007 scanner, often get the BRG pule error, especially after first starting the unit, then often the antenna stops rotating and then starts rotating on its own.
I opened the clam shell on the gearbox, looks good and clean inside. BRG sensor clean and looks like new!
Is it time for a motor?
If yes, what is part number for the motor? My serial number is R087-3666
The correct scanner for the FR-7062 is the RSB0070-059.
It would need to be troubleshot by qualified tech but you might be correct about the motor. The replacement motor is part number 000-169-460.
