Continue to struggle to make the TZT2 fishfinder get close to the performance I had with the Furuno 585 with the same transducer. Fishing in depths of 2500+ this weekend, I adjusted settings all day trying to get it to read bottom(when I never had this issue with the Furuno 585 with the same transducer). Finally got it to read bottom but in the space above the bottom to the surface, there was an excessive amount of "noise" or clutter. I could not adjust that out. Any suggestion on which adjustment would help remove that?
If the answer is reduce gain, won't work, reducing gain eliminates the machines ability to find bottom in this depth.
