If you load in waypoints it will overwrite what you have already.  If you want to create additional points they should be placed on a drive that already has your points from the TZT2 loaded.  Maintain that drive as a master.  So if you are out one day and add a point or 2 directly in the TZT save the entire file to the drive to use as a master file.
