fcv588
dhrace
I'm having trouble with speed over water is not reading on fcv588 the temperature show but no speed I have a 525STID-pwd transducers thanks
If the paddle wheel is backwards the pickups won't function. The pickups inside the transducer only work one direction. If new; I suspect the wheel is turned the wrong direction. Water pressure should hit the flat part of the wheel not the rounded back side. I would recommend inspection of the wheel mounting. When it is out of the water you should be able to push it/spin it and have water speed reflect.
