Hi All. I’ve recently taken delivery of my new Australian built Sailfish catamaran. Unfortunately one of the transducers I ordered have been incorrectly supplied and installed. I generally do bottom fishing at varying depths but the majority of my fishing is between 100-300 feet and have recently started to explore deep drop fishing also. On the advice of my local dealer it was recommended to install a 200-8B and a 38BL-9HR paired with my FCV295. Also as standard the boat came installed with a TZT2 and a SS164 installation. Upon taking delivery of the boat I’ve noticed that it has a 50B-9B installed instead of the 200B-8B. They have confirmed that it was a supply error but unfortunately it’s not as simple as just replacing it with the correct transducer as it’s installed in a custom fit fairing block which needs to be replaced and the manufacturer of the boat is on the other side of the country. They are suggesting that I try and run the 50B-9B at the 75khz frequency and see how it performs as they seem to think that it may be a better option over the 200B-8B.
I am after some advice or opinions on my setup and choices. I have a basic knowledge of transducer beam angles and setup but I’m finding it hard to understand or comprehend why the current install may be a better option over my initial order/recommendation. There’s also the concern with running 200khz(SS164) on the TZT2 and 200khz(200B-8B) on the FCV295. I’m also not overly impressed with the sounder on the TZT2 at this stage although I haven’t had a chance to refine the settings yet.
1. Can someone confirm that running it at a 75khz frequency is possible on the FCV295 as all the information I have seen suggests otherwise and that it’s only possible on the FCV1150?
2. What are the advantages and disadvantages between the 200B-8B and 50B-9B so I can make an education decision around what I would prefer to have installed?
3. Will I see a very noticeable difference between the 2 transducers if one is a 1kw and the other is 2kw?
Many thanks in advance.
