I have an FCV1100L with a B260 transducer, problem i have is it was a bad installation and im loosing bottom at 10-15 knts. Previous owner pocket mounted the ducer flush with the hull, its completely glassed in top and bottom. I am debating on wether to cut it loose from hull and then patch 8"x5" hole, then mount with fairing, or just buy a new ducer and mount with fairing on other side of hull. Ive been reading about the B265 chirp transducers, and im seeing that the fcv1100 can work with this transducer, just not fully chirp capable. How much would the B265 improve my bottom reading? Looks like I would be able to utilize more frequencies to fine tune my display then just 50-200. Is this correct ?
