FCV 800 transducer transmission control
anowal01
Hello. I am looking at installing an FCV800 with a B285HW Chirp and a B260 CW transducer. I want to transmit on the B285HW transducer and display that on screen full time. I want the B260 low frequency running in the background for use of hardness output to a TimeZero install. In reviewing the manual, I understand the different display modes, as well as the ability to turn on/off each transducer port and then in the sounder menu adjust the tx power. So here are my questions -
1) If I have the 2 transducers connected and both XDCR ports set to on, will the unit be transmitting across all 3 frequency ranges (the Chirp high wide, the CW high and the CW low) all the time regardless of what display mode I am running (including have a nav display up) or are only displays actively being viewed transmitted?
2) Does the FCV800 operate similar to documentation I have found for the FCV1150 regarding output of bottom hardness where the bottom hardness output sentence will send the CW low freq as the hardness sentence whenever it is available regardless of what other frequencies may also be transmitted at that time?
3) If I set the sounder menu tx power option to 0, will that affect the transmission power across all frequencies simultaneously?
4) If I set the display to use Chirp HW and CW low split, will the CW high still transmit?
5) In short, what I am trying to determine, is there a way to transmit only the Chirp HW and the CW low at the same time while viewing the Chirp HW on screen and outputting the CW low hardness sentence (ideally with CW high not transmitting)?
Thank you.
1) If I have the 2 transducers connected and both XDCR ports set to on, will the unit be transmitting across all 3 frequency ranges (the Chirp high wide, the CW high and the CW low) all the time regardless of what display mode I am running (including have a nav display up) or are only displays actively being viewed transmitted? The allowable simultaneous modes with those two transducers are: A. CW (B260) High (H) and Low (L) split screen. B. CW L and Chirp H (B285HW) split screen. C. Any of the 3 Full screen. Basically, what you see on the screen are the only one(s) transmitting.
2) Does the FCV800 operate similar to documentation I have found for the FCV1150 regarding output of bottom hardness where the bottom hardness output sentence will send the CW low freq as the hardness sentence whenever it is available regardless of what other frequencies may also be transmitted at that time? My understanding after comparing the units that output Bottom Hardness is that it can use the HIGH or the LOW frequency to determine hardness. That being said, you would have to have the H, L, or Both of the CW mode active to output Bottom Hardness. Basically, at least one of the CW frequencies has to be pinging.
3) If I set the sounder menu tx power option to 0, will that affect the transmission power across all frequencies simultaneously? Yes, that is for times when the boat is out of the water and you need to power the FCV800 up but don't want it pinging away. Other times might be lowering the power output if you are running the FCV800 manually and intentionally want to reduce the output power (such as very shallow water).
4) If I set the display to use Chirp HW and CW low split, will the CW high still transmit? No, only the mode selected will transmit.
5) In short, what I am trying to determine, is there a way to transmit only the Chirp HW and the CW low at the same time while viewing the Chirp HW on screen and outputting the CW low hardness sentence (ideally with CW high not transmitting)? To do that set up a mode that is CW (L) and CHIRP (H). This would be the only Chirp and CW mode that can be run simultaneously and output Bottom Hardness.
Very detailed and clear, thank you.
One follow up question regarding #2. If both CW high and low frequencies are pinging (display set as CW high and low split screen), is the value output in the hardness sentence the hardness from the high or from the low frequency?
Thank you again.
