FCV-600L broken power connector
I've broken the plastic housing on the back of my 600L that holds the power cable in place. Is this a replaceable item?
The power chassis jack connector, for the FCV600L, at the back of the display is Furuno part# 000-154-645. You can order this from your local dealer. The connector is soldered into the board so the unit needs to be taken apart, repaired and put back together. It takes some skill, so you might want to price the service with your dealer or send the unit into the Furuno Service Center.
Thanks for the response. I've never soldered anything other than splicing wires so I think I'll explore the repair route. Thanks again.
