Strider493
Hi Folks,
I have some questions.
I currently have an FCV 585 and a pair of 1KW SS264N transducers. I am thinking about going up a step to the FCV 295. Can the FCV 295 use my existing SS264N transducers? If so, I assume they are hardwired into the unit. Will instructions come with the unit that explain which color wires go to what?
I currently have a single wire coming from the two transducers with a connector for my FCV 585 and, as I understand it, I will need to run the two wires from each of the transducers, cut off the connectors, and then run each wire into the back of the FCV295. (assuming it can use these transducers.) Is this all correct?
Question 2- If the 295 does work with the SS264's, I would eventually like to add a 2 or 3 KW, low frequency transducer like the CA38BL-15HR for deep dropping down to 2000 feet. I would use this 3KW transducer in place of the 1KW 50Khz SS264 transducer that is currently being used. Can the FCV 295 be set up to function properly with the 1KW 200Khz SS264 and the 3KW CA38BL-15HR?
Phew! I hope that makes at least enough sense that you can figure out what I am hoping to do.
Many thanks in advance!
