Hi,
Sorry this is going to be a long one.
I've been running my 295 with SS264N (200khz only) for several years now, it really is a great unit for detecting the hard limestone bottom that we get good fish on.
Typical fishing depths are between 20 and 120m, but I've never had problem getting good readings out to 300m, and pretty much anywhere at any speed, with a slightly broken signal in choppy conditions.
The problem started when I removed the sounder and transducer from my previous boat and fitted to my new one. The hulls are almost identical, same brand, same width, same deadrise, but a metre and a half longer and now with twin outboards, but now I'm starting to lose faith in the sounder/transducer.
The new boat actually had twin Raymarine e95's, a CP450 chirp unit and a TM-265LM transducer factory fitted. I gave them a go, and despite reasonable performance, the lack of bottom lock/bottom discrimination was a big thumbs down from me. So I removed one e95, and fitted my existing gear. I left the tranny, and chirp unit in place for backup - some of our trips involve trailering the boat 1500 kilometres away into the remote North West of Australia, where support (and in fact towns) are minimal to non-existant.
So the first trial after the fitting of the Furuno was concerning, as it was a quick drop in the water at a marina on the way up North for a remote trip. The sounder wouldnt show me the bottom in 2m of water unless I maxed out the gain, even so I could barely get the bottom lock to give a solid return.
I played around with the tranny wires to make sure they had good contact, but nothing changed. Despite no other changes, by the time we hit the water a couple of days later it performed flawlessly. As good as it was in the previous boat. I never stop thinking about intermitant electrical faults though...
Subsequently I have had a couple of trips where the bottom lock return gets broken and basically gives no return. What I find strange is that the right hand screen still reads, but nothing on the left, unless I bump the gain right up, whereapon I get broken and gappy B/L and a useless right hand screen.
So my first thought is that I've damaged the transducer cable during the change, maybe a short or a wire broken. I've given it all a good wiggle with no change.
Next, I thought I'd be cunning and hook up the TM-265 transducer to hopefully establish whether it is the tranny or the 295. Not wanting to de-plug the original cable with the proprietary 11 pin Chirp plug (still waiting for someone to prove to me that the Raymarine Chirp is of any value), I bought a 3m extension cable, deplugged and wired in to the 295, thanks to the excellent information on both this and Airmar's websites. Some advise to anyone trying this approach - the extension cable has different coloured wires inside.
I obviously changed the TXDR settings to suit the different transducer.
So I've taken the new setup out for a play, expecting awesome performance, but what I got was good returns on medium frequency 130khz, with way more breaks in B/L than with the SS264, and on low frequency I'm having the same problems that I had with the SS264 - no bottom lock return.
So I don't seem to have proven anything. I hoped I would either see a broken 295 (HF circuit not working) or everything OK meaning that the SS264 or cable are faulty.
One other thing is that I think I've noticed the 295 screen flicker a bit from time to time, but I honestly can't remember if it has done that all along. It certainly doesn't appear to be linked to the bottom lock problem, but I mention it in case that means something to the experts.
I might slip out tomorrow and try to take some underwater footage of both transducers with my gopro, but I just don't believe that this is bubble related. The hull is plate aluminium with no strakes, and no other obstructions.
Can anyone suggest what I should do next? There arent many fishable days around here, I can't afford to waste them.
Also local Furuno support is likely to be prickley, since the 295 and 264 are of US origin.
Bryan
Bryan
![furuno 036 [640x480].jpg furuno 036 [640x480].jpg](https://furunousaforum.com/data/attachments/0/264-42303114e6a7d0bf9d91ddd6e0e08c2e.jpg?hash=QjAxFOan0L)
![furuno 035 [640x480].jpg furuno 035 [640x480].jpg](https://furunousaforum.com/data/attachments/0/265-66fbae8594edaa27c52d34bfd846d420.jpg?hash=ZvuuhZTtqi)
![furuno 033 [640x480].jpg furuno 033 [640x480].jpg](https://furunousaforum.com/data/attachments/0/266-5a9a91a66546004538c734d72bf21d69.jpg?hash=WpqRpmVGAE)
