FCV 1900B with Airmar R109 LHW
Nick
Hello,
I would like to connect FCV1900B on R109 LHW transducer in chirp mode. I heard that is not possible but I think it is possible, so I'm asking here. When You take look on Furuno fishfinders tap settings table the fields for R109lhw are empty, so I'm little confused with this. For exaple: R109lh and R109lm are ok, like Pm 111lh/lm (that is the same transducer in different housings) All of them using the same low element. "High wide" side is confused also when You look on Furuno tap table. R109lhw and b275lhw using the same 1kw element but b275 is "approved" R109lhw is not!? I'm really confused. :sorry
