808double.e
Just purchased an FCV 1150 with an Airmar CM599C-LH transducer. Can't seem to figure out how to connect them together.
What should the HF and LF jumpers (I guess its called "tap setting") be positioned in? A, B, C, D or E?
On the back cover for the external cable connections there is a wiring diagram,
P4(TD_HF and P5(TD_LF). I assume there are the connections for the HF and LF elements in the transducer.
3 COLD
2 N.C.
1 HOT
Does this mean: 3 (COLD) is HF or LF NEGATIVE, 2 (N.C). No Connection, 1 is (HOT) HF or LF POSITIVE? Each element has a positive, negative and shield wire. Where does the shield connect to?
And lastly, how do I connect the water temp sensor on the transducer to the 6 pin connector on the back of the 1150? Is there a ready made "pig tail" that plugs into the 1150 and I can splice it to the transducer cable, and what leads would that be, and to what pins do they connect to? If there is a "pig tail" what is the part number, so I can order it.
I'm sooo confused. Any and all help is greatly appreciated.
Thank you very much.
3 COLD
2 N.C.
1 HOT
