FAR-2117, Displaying route from ECDIS
Good day for everybody! Need kindly help from gurus. We have installed ECDIS FEA-2107 and 2 radars FAR-2117.
Questioon: what kind of connections or/and settings should present to achieve displaying route on radar(s) from ECDIS? NMEA through EC-1010 or by LAN, or through GPS ?.. Can not get output signal on EC-1010, LAN seems using for radar overlay only...
Will appreciate if somebody throw any idea and direct me to right way. Thanks in advance!
Hello Marconi,
The FEA2107 will output the route to the FAR2117 via LAN. The INS setting in the radar needs to be set to LAN. Also, in the mark menu, go to INS mark, and turn route on.
Lot of thanks, X-band, for reply!
You gave me a hope! But... even after the setting as per your advice route still not coming to radar.
My settings are following:
Menu -> Initialize -> Others -> Ins -> LAN
Menu -> Mark -> Ins mark -> Route -> All
Menu -> Nav Line - WPT -> Nav Line Data -> Ext Data
By the way Radar IP is well pinging from ECDIS, Radar overlay is working fine - means LAN is OK.
Anyway, thanks again, I know now the right direction for my further research, as signal with route data is lost somewhere in LAN.
Additional info: route created on GPS GP-150 is well coming and displaying on our both radars. But it is not convenient way.
SOLVED!
Once more: thanks to X-band for the magic word "INS"!
I've changed settings in FEA2107.
BEFORE: Menu -> Initial settings -> Installation Parameters -> Sensor Parameters -> Radar Echo Overlay / ARPA Communication (LAN) -> Device Interface -> Chart Radar
NOW: ....... -> Device Interface -> Chart Radar with INS.
At least one of radars is displaying route from ECDIS now. Trying to make available on another one.
Wish you all Good Luck!
